Page 5 of 5 FirstFirst ... 345
Results 41 to 47 of 47
Thread: Realtime tuning with Moates RoadRunner
  1. #41
    Sep 2003
    Nope no 98's
    EFILive - The Single version of the Truth
    Larry - HumpinSS
  2. #42
    No 98 support yet. However, I'll do what I can to try and support it. But it won't happen right away. Here's the priority list:
    - 99-02 LS1/Trucks (done, supported)
    - LB7 Diesel (under way, earliest testing looks promising)
    - 03-05 LS1/Trucks (bench testing under way, no results yet)
    - 98 LS1 (have dissected PCM for fitment, will require circuit layout change at least)
    I'll also be putting together a little quick-start documentation guide so folks can understand what is involved to get up and running with this system. It actually is very easy once you've done it the first time. Like so many things in life.
  3. #43
    Quote Originally Posted by madprof01
    just clarifying, this emulator works with 98 ls1 as well? sounds amazing!
    The current design does not, but investigations are underway to see if it is possible to make a version that does suit the 98s.
  4. #44
    Sorry if I am being dense but here is my question...
    I buy the roadrunner 895 and the efilive license for 199, is that everything I need to tune my car?
    [/insert funny quote here]
  5. #45
    Yes. However, you'll need a datalogging solution to see what your vehicle is doing. The EFILive FlashScan cable is an ideal choice as a companion product.
  6. #46
    holy quick post batman
    so do I need to buy the flashscan personal or commercial to do it right? poop time to get a second job for the auto-habit
  7. #47
    Sep 2003
    with the personal version you will be limited meaning you cant do full reflashes. Commercial allows you to do full reflashes and utilize the custom OS's EFILive has provided us with. Personally I woul dget commercial and be done with it.
    Larry - HumpinSS
  1. RR is failing as soon as it tries to update realtime data
    By TFZ_Z06 in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 25th, 2009, 01:25 PM
  2. rr wont update realtime
    By minytrker in forum RoadRunner Real-Time PCM Emulator
    Last Post: March 21st, 2007, 11:04 PM
  3. RoadRunner Real Time Tuning
    By VT LS1 NZ in forum General (Petrol, Gas, Ethanol)
    Last Post: March 18th, 2006, 08:47 AM
