This is a script I have to set a few things, one of which is the DTC/MIL enablers to go into SD mode. You might be able to adapt this for your purpose?
Code:
[Script]
;ID Cal Adj Value Update Area Comments
10= B5001 SET 0.0 . Set {B5001} MAF Sensor Calibration to "0.0"
20= C6002 SET C6002 . Set {C6002} Engine DTC MIL Enablers
30= C2901 SET 0.0 . Set {C2901} MAF High Frequency Fail 1 to "0.0"
40= C2903 SET 0.0 . Set {C2903} MAF High Frequency Fail Limit to "0.0"
50= C2904 SET 0.0 . Set {C2904} MAF Low Frequency Fail 1 to "0.0"
60= C2906 SET 0.0 . Set {C2906} MAF Low Frequency Fail Limit to "0.0"
[C6002]
;DTC Data
P0101= 0
P0102= 0
P0103= 0
