Results 1 to 4 of 4
Thread: Quick ?s
    Feb 2006
    Default Quick ?s
    I was donated a tune, I have a couple quick questions. When I open the tune it has his truck info. Does this matter? Can I change it? Do I need to? Also, it says I can't open my stock tune file to compare with this tune because of the different operating system is there a way around this?
    Thanks, Aaron
    Lifetime Member bobo's Avatar
    Nov 2005
    No way around that at this time because the cal is different on the two trucks. There should be a way to do this on the next version updated of EFILive. You can open two tuning tools at once and compare them that way. You don't need to change the truck info on the other tune. Don't put that tune into your truck. Use your own tune and make changes to it.
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
    Lifetime Member Max Power's Avatar
    Nov 2005
    The best way to do it is to get a stock version of the modified tune you have. Then you do a compare between the two. Then copy all the tables that are modified to your stock tune.
    09 LMM Duramax
    Nov 2005
    If you're into copying stuff!
  1. Quick Question
    By duramax07tmd in forum General (Diesel)
    Last Post: March 16th, 2010, 02:06 PM
  2. Quick IAC question
    By DaddySS in forum Gen III V8 Specific
    Last Post: December 16th, 2007, 05:30 AM
  3. Quick question about the BCM....
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: October 14th, 2007, 03:19 PM
  4. quick ???
    By YANKGTO in forum General (Petrol, Gas, Ethanol)
    Last Post: November 4th, 2006, 06:21 PM
  5. Quick IFR ?
    By ViolatorTA in forum General (Petrol, Gas, Ethanol)
    Last Post: July 18th, 2006, 12:11 PM
