Results 1 to 4 of 4
Thread: efi live wont work with lly?
    New Member titanspanker01's Avatar
    Default efi live wont work with lly?
    i have been messing with my lb7 and the software is working perfect. when it comes to my friends lly it wont read the pcm! WTF am i doing wrong
    Lifetime Member Max Power's Avatar
    Nov 2005
    Update the latest version from their web site. You likely have an old version. Also if you have any aftermarket radio stuff, pull the radio fuse. Also make sure you have LLY selected from the pull down.
    09 LMM Duramax
    Senior Member Racehemi's Avatar
    Nov 2005
    Don't forget to select LLY
    04 2500, LLY/A, 4x4, CC, SB, 285 Toyo's, Amsoil lubes, Access Roll-up Tonneau, ATS Stage 2 trans, ATS 5 Star Converter, Bilstein's, Caltracs bars, Cognito Braces, EFILive, Kennedy Diesel Custom Tuning, Kennedy Diesel headlight harness, Kennedy Dual Lift Pump/Filter combo, Prodigy brake controller, Spa DG 211, Trippin Cyclops overhead gauge mount, , TTS 4" Exhaust, TTS Xtreme Beta, Amsoil Ea filters, Banks CAI
    i downloaded the 7.3.1 again and now it shows lly. thanks for the help!!!!!
  1. any reason why my flash wont work on car after i close the tuning file
    By z28ls1818 in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 12th, 2010, 02:40 PM
  2. EFI live 7.5 or 8.1 wont install
    By -=Mod=- in forum Lounge
    Last Post: November 19th, 2009, 06:55 PM
  3. DSP5 wont take flash? Fuel vs Speed does not work?
    By Mitco39 in forum General (Diesel)
    Last Post: August 13th, 2009, 10:12 AM
  4. ac wont work at idle
    By hot-dog in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2009, 04:07 AM
  5. FTClean Wont work
    By Kiwi Ed in forum Tips and tricks
    Last Post: July 28th, 2007, 10:02 PM
