im having a very similar problem (maybe the same)
i bought mine from dynotune. where did you get yours?
98' White TA A4 TSP 231/237 PP Stage II 59cc heads
401rwhp (unlocked) 1.594 60'-11.60 e.t.-116.98 mph
98' Sport Gold Metallic TA M6 - 13.39 e.t. Bone Stock
My Trans Ams
2006 Chevy Monte Carlo SS 5.3L LS4 (wifes car) stock (for now)
...and blue to battery ground, I presume;Originally Posted by mtnman
yes, these look correct;
when engine is running, measure voltage on red wire wrt blue wire, should be better than 12V.
If you have these backwards, the Windows LC-1 programming application won't find the LC-1 and you won't see the programmed voltages as you posted earlier.I forgot to mention that I had to reattach the the wires for the serial in and serial out connectors. I know the wires are securely attached. Are the connectors the same internally, although one is marked in and one is marked out? Could I have these backwards. I wouldnt think that they're different.
See if it passes the "bench test"; if it doesn't, contact Innovate to see what they can do for you.Originally Posted by WicketMike
I bought mine from Innovate's website.
You're welcome. Let us know what you see.Originally Posted by mtnman
No, I have the blue wire connected to chassis ground (the body of the truck).Originally Posted by joecar
2003 2500HD,E-Fans, LT headers, Corsa catback, Outlaw intake.
With your DMM, measure the voltage between the battery negative terminal and the blue wire (may need 2 people to do this).Originally Posted by mtnman
And also do this...
I measured voltage between the brown and green wires, 1.32 volts. Havent measured other voltages yet, because other wires are behind the dash. I'll keep ya posted.
Joecar, when we're done with troubleshooting this, it may be a good idea to append this (type of troubleshooting) to the lc-1 install manual.
Programmed for flatline 2.5V and you see 1.32V across brown and green...?
Doesn't look good, but we'll see what the other voltages are (brown and white, red and blue).
Good idea, we'll get some kind of troubleshooting steps added.
That is correct.Originally Posted by joecar
