Use CALC.AFR_LC11 or CALC.AFR_LC12.
Do Ihave to change it in this?
CLC-00-110
factor 0.5 1.5 .4 "{GM.EQIVRATIO}*{EXT.WO2LAM1}"
Yes, if you're using EXT.AD1 then change it to this (the green part):
CLC-00-110
factor 0.5 1.5 .4 "{GM.EQIVRATIO}*{CALC.AFR_LC11}/14.7"
if you're using EXT.AD2 then use CALC.AFR_LC12 instead of CALC.AFR_LC11.
This will be:
or
"{GM.EQIVRATIO}*({CALC.AFR_LC11}/14.7)"
I´m confused....
Joe, Do I have to program the LC-1 for EFILive, as says in the the innovate web page?
http://www.innovatemotorsports.com/r...e_tutorial.php
Or this is included in the cal_pids.txt. that I already modified with what you mention in post #13
Just set the LC-1 to factory defaults...
then use the modified calc_pids.txt.
It still not working, I´m think maybe is a problem with the cal_pid.tx, here is my file, and also a log file.
The gauge is working cuz when I move the afr in the scan tool, the gauge change reading as I increase or deacrese the AFR. But the readings on efilive not change as the gauge does.
Post your tune file from which that log was taken.
Something looks wrong with the MAF pid, it looks like it is under-reporting.
Your wideband is showing AFR 10.3, but your LTFT's are negative but not pegging...!!
Post screenshots of your CALC.SELBEN MAF map and CALC.VET VE map.
Are you using CALC.VET [g/K/kPa] or CALC.VET [%]...?
