Need to operate the throttle smoother/longer.
I´m using g/k/kpa, here is the tune file, with the changes.
Don´t worry Joe, take your time, I really appreciate it.
Yesterday I take a new log but this in my car where I now that in CL the VE is not so bad, and I have the same result, When the gauge is showing 13.5 to 14.5 AFR, the scan tool shows low reads 7 the lowest and 10 the highest. With a DMM check the volts in yellow wire and is similar to what the scan tool readings from .1v to 1v. But it suppose to be from 1v to 5v? and the other output from the lc-1 the one that goes to the gauge is between 1 to 5v.
So could I have a bad config. in pid txt?
Any advice will be helpful.
You want the LC-1 brown wire to go to V1 (not the yellow one)...red: to switched 12v
blue: to ground
brown: to white wire of the gauge
yellow: to gauge and v1 device
black: to led and push botton and botton to ground
white: to ground and black wire of the gauge
green: it does not have green.
( if you don't want to swap wires, you can reprogram the LC-1 using the LM Programmer software... but if you do this you have to make a mental note to remember this. )
Also, does the gauge need both yellow and brown wires (the LC-1 user manual shows only yellow going to the gauge)...?
Thank for your time Joe a to you C5 . I made a mistake when typing.
This is how is rigth now:
RED: to switched 12v
BLUE: to ground
WHITE: to ground
YELLOW: to V1 device (volts 0v-1.1v)
BROWN: to gauge (volts 1v-5v)
BLACK: to led and botton to ground
The LC-1 manual says the gauge only needs one wire from the controller and is the brown wire.
So correct me if I´m wrong. I have two options:
1. Reprogram the LC-1 or
2. Route the brown wire from LC-1 to gauge and to v1 device
