Page 4 of 4 FirstFirst ... 234
Results 31 to 35 of 35
Thread: Advice needed, please take a look to my tune
  1. #31
    Which VE table did you start with...?
  2. #32
    Comments:
    - wideband AFR is incorrect (reprogram LC-1 to correct this) <-- this is why Calc.VET is not working.
    - your O2 sensor stopped switching at frame 2728, maybe because PCM sees something wrong.
    Question:
    - why is P0106 disabled in C6001...?
    - what injectors do you have (does B4001 match...?)
    - what is presure measured at fuel rail...?
    So you will need to reprogram the LC-1, undo the VE and MAF tables (go back to previous values), and take a new log.
  3. #33
    Senior Member DocZ28's Avatar
    Mar 2007
    I test routing a wire, option 2, and now the reading are the same. Any way I will try reprograming the LC-1
    And check differences.
    Thank for your help
  4. #34
    Mar 2007
    Comments:
    Question:
    I haven´t see this, I comes from a previous tuner, I´m enabling, and the injectors match but will check again the presure is 58psi
  5. #35
    Quote Originally Posted by DocZ28 View Post
    Thank for your help
    No worries...
    once it's all setup it then goes very easy.
  1. Good N/A Tune but...Going Supercharged I could use advice on a base tune
    By tatasta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 6th, 2011, 09:16 PM
  2. Advice on my transmission tune.
    By ippielb in forum Gen III V8 Specific
    Last Post: October 20th, 2010, 10:53 AM
  3. LS2 with GMPP E67 - advice needed
    By V8RX7 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 3rd, 2009, 12:20 AM
  4. Advice needed
    By JuhaniLS1 in forum Gen III V8 Specific
    Last Post: February 15th, 2007, 01:26 AM
  5. Need advice on a TT408 tune problem..
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2005, 01:17 PM
