Page 6 of 6 FirstFirst ... 456
Results 51 to 54 of 54
Thread: Setting up a FSV2 from scratch...
  1. #51
    Quote Originally Posted by BADCADDY View Post
    I have configured for BB saved pid list, saved tune, updated everything, refreshed, and manually moved options.txt just in case, also programmed all. I'm still receiving no folder error, I can tune, and display PIDs but can't not log. Any idea why I still receive 0185 error code?
    Post some screenshots...
    which folder did you put the tune file on your FSV2's SD-card...?
    is the tune file in .ctz format...?
  2. #52
    Oct 2016
    My tunes work fine, its data logging I'm having trouble with. When I select pid list and press 0/power I get the error message. After adding my controller I made my pid list, validated it and saved in in the predetermined destination as 2009CTSV.txt. Weird it will let me do live display of my pid list but not log it.
ID:	21606Click image for larger version.
  3. #53
    Using EFILive Explorer, show the F3 Data Files tab, and post a screenshot of that...
    I think there might be a folder missing.
  4. #54
    Oct 2016
    You were right I didn't even notice, the Scan folder was missing. No clue how that happened, thank you. This is why you're awesome.
  1. Replies: 4
    Last Post: April 9th, 2011, 06:53 AM
  2. Help setting up LC1
    By Slow73 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 29th, 2009, 03:51 PM
  3. building LS from scratch, what ECU options, etc.
    By general23cmp in forum General (Petrol, Gas, Ethanol)
    Last Post: June 18th, 2008, 03:46 AM
  4. Changing usb cable on FSV2
    By AGRO in forum General
    Last Post: May 2nd, 2008, 01:09 PM
  5. Setting up PLX with V2
    By mtnman in forum FlashScan V2
    Last Post: February 8th, 2007, 07:20 AM
