Results 1 to 7 of 7
Thread: Adjusting the respons ....
    Member Ram Air IV's Avatar
    Nov 2008
    Default Adjusting the respons ....
    I dont know if this is possible but here is my question. On a carburated engine the engine respons direct on how I move the pedal. On my LQ9 with DBW the respons is not as direct as I would like it to be.
    When I push the pedal i responds directly but when I release it will not go down to idle direct. The rpm drops down to 1000-1200 and after a couple of seconds it drops down to idle (600). Is it possible to adjust this and if so, how do I do it?
    M
    Firebird -68, LQ9(LS6 Intake, Comp XR265-HR)/4L60E,
    DSE-Quadra Link/AFX Spindles, Corvette C5-Brakes/Vintage V40 - Michelin PS2 255/335
    Nov 2008
    Hi Joecar,
    The info that you sent me about electronic throttle was about open/close parameters but i think that my throttle close direct, nevertheless the rpm goes down to 1200 and after a few seconds down to 600.
    My plan was to make a scan file so you could see what I mean but I canĀ“t connect to my PCM (a nother problem ....)
    Kind Regards
    Nov 2008
    So now the scan works again (thanks Joecar). I have made a logg file just to show what I mean with slow respons.
    When I release the pedal the rpm slowly goes back to idel but I cant figure out why, what are keeping the engine 300-500 rpm above idel for a while.
    Also log ETCTP if it is available.
    Lifetime Member Chuck CoW's Avatar
    Feb 2006
    Hey there.... Check the link in my signature.... I can fix that for you.
    Chuck CoW
    CoW BOOSTER! Electronic Throttle Enhancement.
    - CLICK HERE NOW FOR MORE INFORMATION! -
    VARARAM, EDELBROCK, AMERICAN RACING HEADERS, BAER BRAKES, BORLA, EFI Live, Magnuson,
    COMP Cams, PROCHARGER, PRO TORQUE, PHADT Racing, INNOVATORS WEST, and more.
    Aug 2004
    Throttle Cracker Table b4309 set it to all 0..
  1. Who needs on the fly adjusting...
    By 2007 5.9 in forum Cummins 5.9L
    Last Post: August 19th, 2012, 12:22 AM
  2. Adjusting fuel used
    By rgullett83 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 28th, 2009, 01:09 PM
  3. Logging for adjusting B1010
    By Cougar281 in forum Duramax LLY
    Last Post: March 9th, 2009, 10:42 AM
  4. speedometer adjusting
    By HioSSilver in forum General (Petrol, Gas, Ethanol)
    Last Post: February 7th, 2007, 12:57 PM
  5. Adjusting O2's for LT Headers?
    By trudynosports in forum General (Petrol, Gas, Ethanol)
    Last Post: August 4th, 2005, 05:26 AM
