Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: Help with CalcVE Tuning Filter
    Senior Member jeff keyuk's Avatar
    Jun 2008
    Default Help with CalcVE Tuning Filter
    Looking to build a Filter for CalcVE {B0101} Map and {B5001} Map or maps?? The following is a filter I have started and would it be correct???
    Hi Jeff, use this one (it should already be in the Name pulldown):
    (note that it says "Include data frames")
Name:	ben filter.png
    Jun 2008
    thank joe! I thought so! Just what do make sure.That's the same filter I used for Auto VE.Table So you use this filter for all the calc VE Tables.
    Yes, that's correct, filtering is the same for any of the tuning procedures.
    Jun 2008
    Hey Joe! Couple of question! In on making a B0101 Map it say on the [Data]Tap to select the Calc VE from the Parameter drop down list,
    There are 4- to pick from
    1 Calculated VE,ben correct(%)
    2 Calculated VE,Ben correct (g*K/kpa)
    3-calcuated VE,not corect(%)
    4-calculated VE,not correct(g*K/kpa)
    I had select # 2 Then on the "Filter". On the last line you said to apply (GM.FTC cell) is not equel to 21.00 cell.) This is not in on my Parameter Drop down list !
    Do I really need it. Thanks Jeff!
    Jun 2008
    Oh Yea! After doing all that, I when't out and did a logging, Everything looked ok! On the B0101 map ,click on the average button ,the cell count when't BLANK ??
    Quote Originally Posted by jeff keyuk View Post
    Yes, select CALC.VET ("calculated VE, corrected") g*K/kPa
    ( on the Data/Row/Col tabs, checkmark Show Names to see the pid names ).
    If you did not log GM.FTC, you can delete that line from the filter (since the line above it ("TP > 1%") covers this, so you don't really need it)
    Post a screenshot...
    the Average button will show the average values in each of the cells... in the map properties goto the Empty tab and check the Empty Cell value, make it lower.
    Jun 2008
    Must be something Ive done wrong!
    URL=http://imageshack.us/photo/my-images/24/jeffsveb0101map.png/][/URL]
    Thanks Joe !
    What did you set the Empty Cell count to...?
    Ok, now click on the average, and click on the apply filter button.
  1. Auto VE Tuning Data Filter Question
    By jeff keyuk in forum Tutorials
    Last Post: August 17th, 2012, 12:27 PM
  2. filter setting
    By myws6formula in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 22nd, 2012, 04:24 PM
  3. Closed Loop Filter- Tuning w/o WBo2
    By Crunkmaro in forum Gen III V8 Specific
    Last Post: August 6th, 2011, 01:02 PM
  4. Help with AutoVe and CalcVE tired last night.
    By pavetim in forum Gen III V8 Specific
    Last Post: December 18th, 2010, 12:49 PM
  5. CalcVE insanity check... duh?
    By Wolfie in forum Gen III V8 Specific
    Last Post: May 21st, 2010, 09:59 AM
