Hey joe ! Can't remember how to sent the log file.
Hey Jeff,
Attach the log file (filename ends in .efi) file like this:
start your reply, and then do this:
5. below the reply box click Go Advanced, scroll down a little, click Manage Attachments (see 1 in pic below);
6. in Manage Attachment popup box click Add Files (see 2 in pic);
7. in Upload Files popup box click Select Files (see 3) and locate file, select it, click OK, file appears in Upload Files popup box;
8. click Upload Files (see 4), file appears in Attachments section of Manage Attachments popup box;
9. click Done (see 5), file appears in Attachments section of the post;
A. finishing typing your reply, and submit the reply.
On the PIDs tab, highlight MAP and MAF and go rightclick->Metric.
Is your MAF failed...?
( I see DTC p0103, this means the PCM is using only the VE )
Wideband voltage is very wobbly...
Hey Joe! P0103 was set at NO MIL , I set it back at ( MIL ) Sorry ! I Did not set it back for close loop tuning! I when't back over all the table I change for the open loop tuning. I will try it again to make a log run ,and I will sent it back to you! Thanks Joe. Slow leaner!
Jeff,
No worries.
Are you doing Calc.VET or AutoVE...?
Ok, then enable the MAF (set C2901-3 back to stock)...
enable MAF DTC/MIL reporting (set C6002 P0101-3 to MIL, set C6001 P0101-3 to A:1-Trip)...
verify that none of the MAF DTC's appear during any drive.
