Results 1 to 10 of 13
Thread: noobie question about widebands
    Member rumblebox's Avatar
    Nov 2010
    Default noobie question about widebands
    with V2 can i just wire the wideband straight into the black box, or do i still need the lambda cable too?
    | 2000 firebird | LQ4 | LS3 top end | 226/231 .600 .602 114 | TCI 3500 | 3" x-pipe under-axle | BMR everything |
    The wideband O2 sensor connects to the wideband controller;
    the wideband controller connects to V2 (using a null modem serial comms cable).
    Nov 2010
    also, is there any way to use the wideband at WOT instead of OL? for every day driving that is.
    May 2008
    Hi, as far as I know, the only way you could use a wideband sensor to do tuning on the go is with the RoadRunner PCM.
    E85 is NOT flex fuel.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Quote Originally Posted by rumblebox View Post
    I'm not sure what you mean...
    do you mean for tuning or monitoring...?
    or for real time correction (see what nevinsb said)...?
    Nov 2010
    How to i connect the LC-1 module to the black box when there's no serial plug? my laptop doesn't have a serial plug either.
    See this (especially the last link):
    You can get a specially made LC-1 null modem V2 cable from TAQuickness
    ( or you can make your own if you're handy with ethernet wiring )
    Nov 2010
    I cant find a 6 pin ethernet cable. Can i just adapt the wires straight into the orage pins?
    It's actually an RJ12 connector.
    No, it does
    not go to the orange pins.
    You will need to cross the Rx and Tx wires ("null modem").
    No serial plug on what...?
  1. Noobie here and have an easy question
    By chargedbird in forum General (Petrol, Gas, Ethanol)
    Last Post: November 24th, 2011, 09:28 AM
  2. BBL killing widebands??????
    By Wasted Income in forum FlashScan V2
    Last Post: September 17th, 2009, 11:26 PM
  3. Noobie first look
    By hhorton in forum Gen III V8 Specific
    Last Post: June 21st, 2009, 07:23 AM
  4. noobie question about LM-1 with V2
    By squealingtires in forum General
    Last Post: June 2nd, 2007, 11:43 PM
