Yes, correct, OL with STFT on stoich cells. Yes it does improve mpg a little.
B3609: set to all zero.
B3647: this is not correct... it should slope richer toward the high map columns (not toward the low rpm rows).
B3618: below 3200 and above 4800 could be richer.
C6001: set the MAF DTC's to 1-Trip or to Non-Emissions (not 2-Trips).
2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
Now own a 2015 1LE camaro
ya, b3647 just loaded what was from my other tune for some reason. It is corrected now. b3618 why would you want it to be richer in below 3200 and above 4800 when it's already commanding 12.8 on the upper r.p.m.s However what would you recomend for below 3200 r.p.m's?
Also what is the main difference between on c6001 1-trip or to non-emissions vrs 2-trips??
I think 13.1 (lower rpm) and 12.8 (upper) rpm are on the lean edge of safe... they are ok if you monitor you wideband.
C6001: P0101,2,3 set to 2-Trips means it takes 2 trips to fail the MAF...
i.e. on the first trip the MAF is not failed but being used (no MAF DTC present)...
and if B5001 is not valid (yours is all zero) the PCM computes a MAF value from the VE table.
Another side note is at 6400 r.p.m's my fuel injector's are running at 96%. It's not very often i run it that high, but the way it skips like it's cutting off fuel from the injector's under load almost makes me think that one my injector's have failed.. My question is if an injector was bad wouldn't it not work period? This agian is just a guess i'm making.
after adjusting A0014 (I.A.T. ve multiplier) it made no defference as my car cutting out, however it did infact rich'n the mixture down to 12.2 a.f.r.
