Results 1 to 10 of 13
Thread: Any way to make a new alarm in V2?
    May 2012
    Question Any way to make a new alarm in V2?
    Is there the ability to make a new alarm parameter in the V2?
    Ive been dealing with reduced power issues on an LS3 swap and would love to make an alarm that would elicit when the TPS 1 & TPS 2 percentages were more than say 4% apart from one another.
    Not sure if this could be done???
    Any thoughts would be appreciated.
    Thanks,
    John
    Yes, start V8 S&T, goto BBx, for pidlists matching your ECM (delete all others), add/modify a pid for your TP, at the bottom you can set an alarm, Save, Program.
    I don't think the alarm for a pid can reference other pids (seems not).
    May 2012
    Joe,
    Thanks... That's my problem...
    I need TPS1% to alarm when lesser or greater than TPS2% by 4%......
    If we can't reference other pids it won't go...
    Thanks anyway!
    John
    Jul 2007
    What error code gets logged with your reduced power mode?
    May 2012
    Simon,
    P2135
    Thanks,
    John
    Jul 2007
    Ahh, OK then. So just logging the two PIDs and reviewing doesn't give enough info? Actually, is there a way to force a flag in the log when a DTC is triggered? That would be a very nice option (hint,hint....)
    May 2012
    What we have discovered for this GM issue is that prior to the reduced power episode the TPS1 & 2 percentages will start to split, more than 2%, increase progressively and when the difference is 6%-9% throw the vehicle into RP or in some instances, shut the vehicle down as a perceived safety precaution.
    What I would like to do is have an alarm that when the TPS's sensors split to 4% I can anticipate that I will soon be experiencing a RP episode, make sure I'm in a pull off lane or safe place to work through the episode. Basically I can keep my eyes on the road and have the alarm be in indicator that a problem is about to present itself until I can resolve this issue in my specific situation.
    More of a personal issue, but nonetheless something I wanted to see if the software could accomplish until I get this resolved.
    Thanks everyone.
    John
    Make a calculated PID that calculates the difference between the two TP PIDs, then place the alarm on the calculated PID.
    Quote Originally Posted by swingtan View Post
    If the DTC you want to monitor is an emissions related DTC, just log MONDTC. It won't tell you what DTC was tripped, it will only tell you the number of DTC's that are set. But if you're only chasing one it should be pretty obvious in the log when it tripped.
    Hi Paul, can you do this with V2...?
  1. Disable vehicle alarm
    By Gregs in forum General (Petrol, Gas, Ethanol)
    Last Post: March 30th, 2012, 09:13 AM
  2. V2 audible alarm
    By Gelf VXR in forum FlashScan V2 BB Logging
    Last Post: July 2nd, 2010, 08:51 PM
  3. Cant turn off low coolant alarm LLM
    By DuraBurb in forum Diesel
    Last Post: June 30th, 2010, 07:17 PM
  4. cant shut off low coolant alarm in DIC?
    By DuraBurb in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 27th, 2010, 12:23 AM
