Results 1 to 8 of 8
Thread: B8024 and 8025 High Speed Mode
    May 2012
    Default B8024 and 8025 High Speed Mode
    Gents,
    Looking and trying to learn the E38 I've noticed that after a dyno tune my High Speed Mode RPM Enter {B8024} was left at 500
    My High Speed Mode RPM Exit {B8025} was left at 400
    These were initially set at 4000 and 3900 respectfully.
    Can anyone advise on if these should go back to the higher values and if so what their intended purpose is?
    Thanks in advance,
    John
    Senior Member Dieselman's Avatar
    Apr 2010
    If I can remember correctly these are the settings for when the ECM uses the MAF readings for all airflow measurements. I take it the tune was a MAF only tune and not Speed Density ??
    Happy to be corrected if I'm wrong
    Ben
    May 2012
    Yes, Its MAF only...
    Just wondering if there are advantages to decreasing those numbers or they need to be moved back.
    Thanks,
    John
    Lifetime Member Rhino79's Avatar
    Jul 2006
    This is very popular on e38's and I have seen it help on transient fueling in the lower rpm cells on some setups.
    Head Calibrator
    Gwatney Performance Innovation
    Jacksonville, AR 501-982-2102
    If the E38 B8024/5 are the same as the LS1B B0120, then setting them to 500/400 disables the VE (i.e runs MAF only).
    May 2012
    I would imagine then that these tables are probably disabled to dial in the MAF and might not have been set back.
    Looks like I've been running MAF without the VE tables.. In any event it ran great, but I'll try setting them back to stock and see how the engine reacts.
    Thanks,
    John-
    Aug 2010
    Hello John,
    Do you know what tuning software your tuner used ? The reason I ask, is with EFILive tuning both the VVE and the MAF is reasonably straight forward. Not so with other tuning softwares. Some tuners will tune strictly MAF only (never tuning the VVE).
    So, perhaps your tuner calibrated both the VVE and MAF tables, and simply omitted to return the MAF to high speed function. Or, perhaps the VVE was never tuned. Just be careful if you make any changes to the tune. Would recommend a WBO in place as a precaution.
    Regards,
    Taz
    May 2012
    Thanks Taz... Looks like they are going more MAF based than VE...
    This will give me a chance to learn and work with the VE tables to see which work better or if using them combined is the way to go.
    Best,
    john
  1. 6th getting locked out at high speed!
    By trailermasher in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: August 20th, 2022, 01:19 PM
  2. High speed onboard datalogging
    By limited cv8r in forum RoadRunner Real-Time PCM Emulator
    Last Post: September 14th, 2012, 04:35 PM
  3. high speed scaning
    By redhardsupra in forum Gen IV V8 Specific
    Last Post: January 14th, 2008, 08:54 AM
  4. high speed flash
    Last Post: May 16th, 2007, 02:13 PM
  5. Use high speed
    Last Post: July 6th, 2006, 02:43 PM
