Why would the car i'm tuning currently go so lean on a hotter day after I dailed in the VE pretty close a couple days before? The car was setup for AutoVE tuning (SD and OL)Originally Posted by joecar
Is it because of open loop?
1992 Turbo LSX Notchback Mustang 275 radial car - under construction
2008 Sierra 2500HD Duramax
the pcm tables arnt 100% accurate, so your afr will go off a little, you can try to get to the bottom of the charge blending, or other tables. But often IMO its easier to adjust table A00014 in OS3 to get it in line. There is some info on this, but I run 1% adjustment per 10*C.
2014 VF SV LS3 Maloo.
you know... i have seen drifts of 7-10% easily from night to day when humidity gets to dew point and such at night.... there are some nights where there is NO Humidity that it doesn't drift.... i am working on that still...
No.. this could be because of IAT Heatsoaking. check that out...Originally Posted by Chris81
