Results 1 to 3 of 3
Thread: DVT Idle Relearn
    May 2012
    Default DVT Idle Relearn
    Searched for procedure, but came up dry.
    Do you do this procedure with Key On, Engine Off or Engine On?
    Replaced the throttle body on an E38 equipped vehicle and believe I might need to relearn the throttle body settings.
    Any guidance would be appreciated.
    John
    Typically you just let it idle in neutral and in gear for a few minutes...
    May 2012
    Thanks Joe... The DVT function only works with Key On, Engine Off....
    I agree it probably does not do much with the E38 that your suggestion doesn't do.....
    Thanks again.....
    john
  1. dvt noob
    By blazinblue in forum General
    Last Post: January 17th, 2009, 12:37 PM
  2. Help!! No idle and can't perform crank relearn
    By onegonewild in forum Gen III V8 Specific
    Last Post: October 16th, 2008, 03:42 PM
  3. Standalone DVT?
    By Cougar281 in forum FlashScan V2 BB Logging
    Last Post: July 12th, 2008, 01:58 AM
  4. Idle Relearn?
    By RevGTO in forum General (Petrol, Gas, Ethanol)
    Last Post: January 22nd, 2007, 07:21 PM
  5. problem lowering throttle idle for ckp relearn
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 4th, 2005, 08:22 AM
