Results 1 to 5 of 5
Thread: 2004.5 LLY can I use 2006 LLY tunes?
    Oct 2012
    Default 2004.5 LLY can I use 2006 LLY tunes?
    I have a buddy that has a handful of tunes from his old 2006 lly twin turbo. I wanted to know if I could use those tunes on my 2004.5 lly with twin turbos. We used the same MPI kit, but I upgraded to the 480S vs the 475.
    Will I have ecm issues, or will the tunes work?
    Chris
    Mar 2009
    06LLY is a LBZ for all intesive purposes, so no they will not work.
    Oct 2012
    Quote Originally Posted by THEFERMANATOR View Post
    Can I copy the tune file set ups? Basically look sat the configuration and adjust the LLY accordingly?
    Mar 2009
    COMPLETELY different tuning strategies as they work completely different from each other. 04-05 LLY is a DELPHI ECM whereas the 06 LLY/LBZ is a BOSCH ECM. The DELPHI does everything in fuel calculations where the 06 LLY works entirely on a torque based calculation.
    Oct 2012
    I appreciate your help on this. Yesterday afternoon, I saw exactly what you described. I am loading the speed, tire size, and gear ration changes.
    I am also throwing a mas air flow sensor code. - do you if I can copy these parameters to get the code to stop coming back. What is also crazy, I am setting off 1 MAF, and 3 EGR codes -but no check engine light? I would have thought a check engine light would have set.
    Here is my thought:
    1. - calibrate
    2. get codes to stop being thrown
    3. get the final tunes
  1. 2006 lly c5500 help!!!
    By rcozz1 in forum Duramax LLY
    Last Post: May 20th, 2012, 03:57 AM
  2. 2006 Kodiac LLY
    By GMC-2002-Dmax in forum Diesel
    Last Post: February 16th, 2012, 01:50 PM
  3. 2004.5 LLY EGR Block???'s
    By GAMEOVER in forum Duramax LLY
    Last Post: February 20th, 2011, 11:38 AM
  4. 2004.5 LLY limping trans?
    By Mr.Blister007 in forum Duramax LLY
    Last Post: September 1st, 2010, 12:34 PM
  5. 2004 LLY Dual alternators
    By s10mods in forum Duramax LLY
    Last Post: March 29th, 2009, 01:45 PM
