Results 1 to 10 of 15
Thread: Tune File Depot??
    Senior Member Chuck L.'s Avatar
    Feb 2006
    Question Tune File Depot??
    Am looking to get the short pulse, batt offset, flow rate, etc, on the GM 12576341 [Bosch 0280158051] inj.
    Thot since it's supposedly an LS3, LS7 inj, I could find the info in a stock tune.
    Every tune I open shows "Bad", and is blank.
    Obviously, there's a simple answer.... It just evades my feeble mind.
    [My PC has never been hooked up to a vehicle]
    UPDATE:
    Got the laptop from the shop, and the tun files will load and open on it just fine. Must be something missing on the PC....
    TIA,
    Chuck L.
    CODY Motorsports
    Fuel Injector Service
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    Hi Chuck,
    On your PC sounds like you will have to uninstall and re-install.
    Cheers
    Joe
    Feb 2006
    Joe, thanks! Will try that.
    Chuck L.
    CODY Motorsports
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    Feb 2006
    Deleted all programs and reloaded 7.5 and 8.. STILL the same thing. I have also deleted the bad files in the bin , and reloaded it, using a thumb drive, out of the laptop. Same thing. The tune opens just fine on the laptop,,,
    The T42 tun file works on both the PC and the LT. They were d/l'd at the same time.
    Chuck L.
    CODY Motorsports
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    Feb 2006
    82 views and ?? I must be the only user to ever have the issue.............
    Chuck L.
    CODY Motorsports
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    Hi Chuck,
    Sorry, I somehow missed the updates to this thread...
    I'll notify Tech Support.
    Which Windows OS are you running on your PC...?
    Chuck,
    post one or two of the files that open bad so we can try them.
    Quote Originally Posted by Chuck L. View Post
    When you re-install V7.5 you will be asked "Do you want to keep the registry settings?"
    It is possible one or more of the settings is causing the software to not load the files correctly.
    Select NO as an answer to that question. That will revert all the settings back to install defaults.
    Feb 2006
    Talking Update....
    Chuck,
    Joe, check your email. I sent them to you on 10/22.
    Blacky, do I have to dump and reload the program, in order to revert to default registry settings?
    Here's a tune I d/l'd from the depot.
    Thanks for the help!
    Chuck L.
    CODY Motorsports
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    Chuck, ok I'll check my email later today.
    Cheers.
  1. Tune file
    By chixperformance13 in forum Tips and tricks
    Last Post: October 24th, 2012, 03:45 AM
  2. Replies: 10
    Last Post: July 7th, 2012, 07:52 AM
  3. Files from Tune Depot
    By LinearX in forum Cummins 6.7L
    Last Post: April 6th, 2012, 09:45 AM
  4. Looking for a Tune.file for a 02 tahoe
    By 02Tahoe28 in forum Gen III V8 Specific
    Last Post: October 2nd, 2008, 01:53 PM
  5. need help with tune file. Please look
    By tgeers in forum Custom Operating Systems
    Last Post: July 11th, 2008, 04:17 PM
