Thank you Joe forthe walk through i will try it out as soon as i get to m laptop. I have saved plenty of PID files to use on other situations but for some reason i cannot save the maps i create in the scantool?
You should be able to save the maps... post a screenshot.
Cells: first checkmark Constrain cell size.
Empty: should be able to set an empty cell count.
Color: checkmark Colored and High Constrast.
I think i see where the problem is. You are just explaining how to create a map in which i already understood. I was thinking I could make a target A/F map that would link with the normal map and is why we are not understanding each other. I have made the maps before but the LC1 is not showing in the cells (histogram logging).
As simon was saying with the short term fuel trim I take it i just load that pid in the data of the map and can see where i am to do some of the ve.
Also is there a way to make an AF target map or is there a table in the tuner?
LOL im sorry.
I believe you were walking me through how to make a map like stated in the Auto VE tuning guide, correct? If so I understand fully how to do this. I have made map A OL VE normal, map B OL VE extended etc!!
I thought you meant if i make a map that i could make another with a target AF (desired AF) that I could reference. Most other software I use has a target AF that makes it nice and easy to dial in each cell very fast.
And for the LC1 i was just pointing out it was not logging the correct values like it should. The type of logging in the cell (map) is called Histogram logging correct? I was hoping to overlay what my actual values were over my target AF which would have the identical X & Y axis!
Never mind!!! I took the stock serial cable that came with the V2 and found a 2.5mm jack cable cut them and put a weather pack connector between them.. LC1 in serial working flawlessly.
Well everything is working fine and going smoothly as far as logging. When pasting with multiplying to the map table if i have no cell count in certain cells it multiples to zero of course and causes the map to go flat and only spike the areas i held in steady state? I tried a few other paste options but no go!! I am puzzeled on this step.
here are a couple logs
AF_0001.efi
AF_0002.efi
