Results 1 to 10 of 13
Thread: rpms
    Oct 2012
    Default rpms
    I wanna lower my rpms how do i do it and what table do i need to change iam new to tunning and just messing around with it
    Oct 2009
    Anyone know
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    You want to lower your RPM limit? If so look at B1106 and B1102. You can control the fueling limit using those two tables.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
    Oct 2012
    What do I need to change in these tables iam New to tunning
    Jun 2011
ID:	14087 The easiest way is to find the max rpm you want to run and set the cell after that to 0. That keeps the truck from fueling above that cell. Just out of curiosity why do you want to lower your rpms?
    423-506-7427
    Jun 2011
    also keep in mind that lowering the RPM limiter to less than stock will definately affect WOT shifting.
    423-506-7427
    Oct 2012
    Iam wanting to lower it at ldle is this what I need to do
    Jun 2011
    No, to adjust idle speed you use table B0701. It is pretty self explanatory and works off of coolant temp.
    423-506-7427
    Mar 2009
    B0701, B1201, and B0756 to keep it from surging at the lower idle speed at slow speeds.
    Lifetime Member LB72004's Avatar
    Dec 2011
    Quote Originally Posted by THEFERMANATOR View Post
    dont forget B0755 for P/N
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
  1. RPMs bouncing at 2-3 shift!
    By shadyst in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 8th, 2009, 07:50 PM
  2. WOT then can't get RPMs
    By JOHNGEAR in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 14th, 2008, 03:31 PM
  3. shift rpms tis rpm or engine rpms
    By 69camaro5speed in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 25th, 2008, 07:01 AM
  4. Need more rpms
    By smknmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2008, 09:39 PM
  5. Occasional KR @ medium RPMs?
    By Garry in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2006, 12:06 PM
