Results 1 to 4 of 4
Thread: Error $0109 after update?
    Oct 2012
    Default Error $0109 after update?
    I originally tried to program a tune to my car, and was given an error $0600 while programming. I thought the tune might have been corrupt, so I cleared the tunes off my autocal and then put them back on again. I also checked the firmware and it offered me an update which I proceeded with. I received an error during the update, and now my autocal just flashes and gives me error $0109 constantly.
    If someone would be able to help me fix this, it would be much appreciated.
    After you updated the firmware did you program all the BBx configuration...?
    Oct 2012
    Whenever I clicked program it would give me the same error. I left my autocal at home but will try to check it out later.
    Did you do this:
    - install V7 build 211 and V8 build 203...?
    - flash firmware 2.07.35 int your V2...?
    Does the V2 LCD show the menu...?
    Are the amber LEDs flashing alternately...?
  1. Replies: 8
    Last Post: March 20th, 2018, 06:47 AM
  2. Error $0109
    By gippy in forum Lounge
    Last Post: September 10th, 2012, 11:57 AM
  3. Error $0109
    By scooter_mack in forum AutoCal
    Last Post: February 12th, 2011, 06:41 PM
  4. Error code $0109 after update
    By Big Block in forum FlashScan V2 BB Logging
    Last Post: April 13th, 2008, 12:31 PM
