Results 1 to 6 of 6
Thread: Re-adjusting the Rows, etc
    May 2012
    Default Re-adjusting the Rows, etc
    Ok here is my delima. I have EFILive and have tuned my truck with it (2003 S10 4.3/5speed 1MB PCM for reference). I also have a spare PCM with a Supercharger tune on it. I have the Supercharger not installed yet. When I install it, the easy thing to do is put the new PCM in. However, Id rather use my stock one and change the tune myself saving me money by not needing to waste another credit on this same truck.
    I got EFILive after I got the Super and PCM that came with it
    The Super's PCM was tuned with HPT. The tuner sent me the HPT file at my request. Obviously EFILive wont read the file. I downloaded the Beta Demo HPT, so I can open and read the HPT file from the Super's PCM tune. I want to read and apply the changes to my PCM using my EFILive and that way I can tweak as I go since I invested in this.
    The biggest PITA is that the rows are opposite in EFI as they are in HPT. (If RPM vs Map, in one RPM is across the top and Map down the side, and the other is exact opposite.
    So, can either HPT or EFI live rows and columns be changed around to mirror each other? Sure would help and make life easier
    Oh, its a different injector too and those changes I have for the mostpart done. Tho I noticed some things are called by different names it seems in the 2 softwares.
    The EFILive tunetool has a transposing tool, when viewing the calibration/vin info, click on the Conversions tab.
    The tables may be named differently, but when you compare their content and axes you can match them up.
    May 2008
    Paste it into excel and flip them around?
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    See this:
Name:	tunetool transpose.png
    May 2008
    Guess you learn something new every day.
    48 LB injectors
    T70 turbo.
    May 2012
    Cool thanks, after my Build 211 Update is done I will have time later to play with this
  1. Adjusting the respons ....
    By Ram Air IV in forum General (Petrol, Gas, Ethanol)
    Last Post: November 19th, 2012, 01:34 PM
  2. Who needs on the fly adjusting...
    By 2007 5.9 in forum Cummins 5.9L
    Last Post: August 19th, 2012, 12:22 AM
  3. Adjusting fuel used
    By rgullett83 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 28th, 2009, 01:09 PM
  4. speedometer adjusting
    By HioSSilver in forum General (Petrol, Gas, Ethanol)
    Last Post: February 7th, 2007, 12:57 PM
  5. Adjusting O2's for LT Headers?
    By trudynosports in forum General (Petrol, Gas, Ethanol)
    Last Post: August 4th, 2005, 05:26 AM
