Results 1 to 10 of 13
Thread: bad BBx log file
    Senior Member restless@westnet.com.au's Avatar
    Aug 2008
    Default bad BBx log file
Name:	trans log file.png
    bugger i just drove 40k and did a log this is how it came out is it corrupt ? or have i got some setting wrong ,or was the log to long about 30min
    data # are way out to like rpm 68,000
    water temp 256 c. ect
    how do i post a log file ?
    I JUST went and did another 5min one and its the same whats wrong ? i have re configured it as well
    all the old log files play back no problem ?
    thanks
    Aug 2008
    OK i have borrowed a friends v2 and laptop
    to see if the log works on another PC (no its still corrupt )
    i transferred the log to his v2 using my PC still corrupt
    i then removed the TCM pids i put in yesterday before i did the log and did a small log just idling in the shed IT WORKS fine so it must be something to do with the TCM T43 PIDS i loaded ? (dont know witch one )
    any reason for this ? if you give me an email adress i can forward the log or tell me how to post it here
    thanks
    Remove all the TCM pids... and then add them back one at a time until you find the one(s) that don't play.
    For posting log/tune files, see post #22 here: Help-with-CalcVE-Tuning-Filter
    Aug 2008
    yer i will but not this weekend LOL
    Aug 2008
    hi joe
    just did a log of the trans arond town
    does the TTC only come on with very little throttle
    what sort of presure limit is normal ?
Name:	trans log tccp.png
    Yes, the TCC is applied at low throttle when vehicle speed is relatively low... check the TCC apply/release tables.
    Aug 2008
    hi Joe
    OK ill check it out
    can you tell me witch table to look at to stop it kicking down from 6Th to 3 rd at WOT (very annoying and dangerous and not good for the box when over taking on the highway with 1000 + NM TRQENG )
    is it WOT > SHIFT SPEEDS ?
    i just don't see a parameter saying 6>3 only 4>3 etc
    so do you have to work your way down from 6th to 3 third
    thanks bob
    Hey Bob,
    I'm not sure about the 6L80/90... I'll have to take a look at the tables... you might have to edit the shift tables to maintain a gear longer (vs easily downshifting).
    Edit: name corrected.
  1. Bad stumble - what should i log
    By Tracyrr in forum Gen III V8 Specific
    Last Post: July 26th, 2011, 12:50 PM
  2. Can't BBX full flash (Error $0502, script file not found)
    By spandit in forum FlashScan V2 BB Logging
    Last Post: April 14th, 2011, 09:34 AM
  3. Allison 6 speed bad file format
    By dineauto in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 21st, 2011, 03:01 AM
  4. Log file help.
    By aaronr in forum Gen IV V8 Specific
    Last Post: September 21st, 2010, 03:27 AM
  5. 97 PCM "Bad bin file format"?
    By caver in forum General (Petrol, Gas, Ethanol)
    Last Post: October 19th, 2005, 12:13 AM
