Results 1 to 9 of 9
Thread: Convert .cal to EFILive
    Mar 2011
    Default Convert .cal to EFILive
    I found a tune for a 2004 LQ4 Silverado with a manual transmission. I would like to convert it to a format that EFILive will work with. If this isn't possible, could someone please reference the VIN in the filename and retrieve this for me? It should also be added to the repo, lots of guys are doing this swap and coming up empty handed. I want to look at the idle and some other tables and adapt my automatic tune to suit.
    Many thanks
    Erik
    2004 6.0L LQ4 4x2 3-4T Manual Trans 1GCHC29U94E338078.cal
    What program generates .cal files?
    I think TunerCat uses .cal filenames.
    I don't see any 2004 LQ4 on www.tunefiledepot.com...
    [ hmmm, and it's a manual...!?!? ]
    Aug 2008
    Here ya go.........
    The attached text file should have the info you need.
    If I had a spare 1mb pcm laying around Icould convert it for you.
    Mar 2007
    I have a LQ4 automatic trans stock calibration out of my 2500 Suburban if you want it.
    May 2008
    Hi, if you can save it as a .bin file from tunercat, efilive can read it.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Aug 2008
    Quote Originally Posted by nevinsb View Post
    It can be saved as a .bin only when reading it.
    I do not have a spare 1mb pcm.
    Mar 2011
    I got it many thanks!!!
  1. help! convert to ETC/drive by wire
    By DURAtotheMAX in forum Gen III V8 Specific
    Last Post: June 17th, 2009, 08:46 PM
  2. Convert ETC to cable TB
    By xtreme in forum Gen III V8 Specific
    Last Post: March 23rd, 2009, 10:52 PM
  3. Convert 98 to 02
    By ChipsByAl in forum Gen III V8 Specific
    Last Post: June 26th, 2007, 05:23 PM
  4. Convert 2000 to 01 or 02 system
    By DaddySS in forum Gen III V8 Specific
    Last Post: June 8th, 2007, 01:56 PM
  5. Convert LS1Edit File to EFILive ... Help!
    By superls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2006, 03:00 PM
