Results 1 to 7 of 7
Thread: High milage 2001 Denali cold idle
    Member Ritch's Avatar
    Feb 2007
    Default High milage 2001 Denali cold idle
    Hopefully, someone out there can point me in the right direction before I get too carried away.
    This is a 6.0L Yukon Denali has 309,000km with some minor mods. I bought it with the cats deleted. It also has one of those dumb throttle spacer "tornado" air spinny thingys. Usuallly it runs very well, except... When it is freezing out and the engine is cold. The engine will fire and then really misbehaves until the engine temp comes up a little. Sometimes it stalls after start up. I am tempted to lower the desired airflow a bit. But I suspect there may be a mechanical issue instead. Here is my tune and scan.
    Cold Idle Issue.efiYukon WT_0001.tun
    I have noticed that the IAT is not really correct, because it was below -10deg C
    ____________________________
    1999 GMC, rcsb, 2wd, 5.3, XR275HR-12
    Radix magnacharger mp112
    Long tubes true duals, $L60E
    Dec 2006
    Does it smell rich? How does throttle body gunk look? Sorry, running to work and no time to look at log. You did the right thing by posting it, that's where your answer will be. Also, those things are known for fuel pump issues.
    8.7 @ 84 (1/8 mile) bolt-ons
    Fix the physical problems first...
    - replace IAT sensor since it is bad,
    - check operation of other sensors,
    - replace front O2 sensors anyway,
    - remove and discard the tornado,
    - clean MAF, replace air and fuel filters,
    - replace spark plugs and wires,
    - replace PCV valve and hoses,
    - check for leaks in AIR and EVAP plumbing,
    - run cleaning additive thru fuel.
    Feb 2007
    IT was the intake gaskets leaking...
    Dec 2006
    Glad you got it sorted and thanks for the update!
    Lifetime Member Gregs's Avatar
    Sep 2008
    Quote Originally Posted by Ritch View Post
    Ahh shoot I'm 4 days too late. Does it count if my wife heard me call out "intake gasket" after reading your first post and before scrolling to the bottom of the thread???
    While you're in there checkout your knock sensors
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Thanks for the update.
  1. High RPM Cold Start P/N
    By Protec in forum E37, E38 & E67 PFI ECM's
    Last Post: August 31st, 2012, 03:36 AM
  2. Replies: 1
    Last Post: August 21st, 2012, 01:39 AM
  3. Cold start perfect, Warm start flares high
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 12th, 2009, 09:36 PM
  4. Cold start idle help
    Last Post: May 25th, 2006, 08:17 PM
  5. OK, Getting frustrated... Damn Cold Idle!
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: November 28th, 2005, 02:13 PM
