Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: AFR Nightmare
  1. #21
    Oct 2006
    Calc_Log_111012.efi Joe, I don't know if you looked at the previous one I posted, but I've logged and posted this one up today so I'd be double sure it was done with your calc_pid settings.
    2000 Formula: 12212156, bolt-ons, 3600 stall, 3.42's.
  2. #22
    Hi Rev,
    Did you select the pids CALC.WO2 and CALC.WO2BEN...?
    Note that the pids CALC.AFR_LM11 and CALC.BEN_LC11 are not correct since you programmed your LM-1 to look like an LC-1.
  3. #23
    Quote Originally Posted by RevGTO View Post
    No success - AFR's still read in the 20-30 range. Joe, are you sure that {CALC.WO2.lam} is the correct function in *CLC-00-110 for analog? The pid system description shows it as WO2-Serial. If that is the case, would {CALC.AFR_LM11}/14.7 perhaps be correct?
    No it leaves it at 10.00 but changes the 20.00 to 19.99 or 20.01 for some reason.
    Yes, CALC.WO2.lam is the correct pid, it follows your LM-1's programmed analog channels.
    The description should be corrected in that calc_pids.txt file (should not mention "serial" anywhere).
  4. #24
    Hi rev,
    Ah, what I meant by this:
    CALC.LM11 is the pid for the LM-1 programmed to default setting.
    was this:
    your LM-1 is programmed to look like this:
    - LM-1 channel 2 (V1 EXT.AD1): same as LC-1,
    - LM-1 channel 1 (V1 EXT.AD2): set to constant 2.5V (for purpose of calculating voltage offset);
    so you don't want to use the LM-1 default pids (CALC.AFR_LM11, CALC.BEN_LM11)...
    you want these pids:
    - CALC.WO2 (which has units for V, AFR, LAM, EQR),
    - CALC.WO2BEN (defined in terms of CALC.WO2.lam and GM.EQIVRATIO),
    - GM.EQIVRATIO (see previous point).
    Edit: corrected LM-1 channels.
  5. #25
    Oct 2006
    Is your LM-1 currently programmed as you said above:
    Analog Output One:
    2.501v @ 10.01AFR
    2.501v @ 19.99AFR
    Analog Output Two:
    0.88333v @10:1 AFR
    4.21667v @20:1 AFR
    Yes, this is how it is programmed. But in the following post, if I understand it correctly, you seem to have them reversed. I take it your calc_pids file is for the above rather than below:
    Ah, what I meant by was this:
    - LM-1 channel 1 (V1 EXT.AD2): same as LC-1,
    - LM-1 channel 2 (V1 EXT.AD1): set to constant 2.5V (for purpose of calculating voltage offset)
    Sorry if I'm confused, just trying to sort through it all ...
  6. #26
    Ah, yes, sorry, my mistake
    ( please, most certainly question something if it does not make sense )
    I corrected post #24 above to read like this:
    Quote Originally Posted by joecar (correccted LM-1 channels)
    Yes, correct, the calc_pids.txt file matchs that (EXT.AD1 is the voltage mapped AFR, EXT.AD2 is constant 2.5V).
  7. #27
    Oct 2006
    Ok, good, thanks. I haven't had time to mess with it all week, but I'll get the all the correct pids selected and hopefully log tomorrow.
  8. #28
    Oct 2006
    Success! I finally got the correct selection of pids figured out and now my logged AFR is matching my LM-1 display. Thanks for all the help, Joe! I've confirmed that my WOT AFR is swinging wildly lean, so now on to solving that problem. But that will be a topic for a new thread.
  9. #29
    No worries, glad you got it working right
    Remember to save your new calc_pids.txt file some place.
  1. Commanded AFR not equal to WBo2 AFR at idle.
    By macca33 in forum Gen III V8 Specific
    Last Post: April 6th, 2012, 11:56 AM
  2. e38 large cam nightmare.
    By Mike@sic in forum E37, E38 & E67 PFI ECM's
    Last Post: November 7th, 2011, 12:55 PM
  3. Cold AFR doesn't follow commanded AFR
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: August 17th, 2009, 01:50 PM
  4. Upgrading Nightmare. =(
    By Stealth97 in forum FlashScan V2
    Last Post: March 3rd, 2009, 07:53 PM
  5. 7.5 Software update nightmare.
    By JOHNBOY in forum Tips and tricks
    Last Post: November 23rd, 2007, 09:42 AM
