I eventually want to boost my truck after getting the hang of EFI Live. I have seen the ZR1 map sensor is a step up for speed density tuning. I will never really need a 3bar. So I was playing with my maps and trying to get this to work in the VE table but am unsure of changing the VE table correctly?
So i changed:
- ZR1 map part # 12592525
- Map sensor linear: 312.50 kpa
- Map sensor offset: -11.25 kpa
{C6301} map sensor scalar from 94.4336 to 312.50
{C6302} map sensor offset from 1.5 to -11.25
I return to {B0101} Main VE table and the Map scalar doesnt change. I have tried to change it but dont see where i can change the cells? Can I do this or no?
~*** This is all bench testing and not being flashed into my truck. I am just trying to familiarize myself with the tables and limits of the software and hardware***~
Opinions and options will be taken.
Also I havent looked to see if I actually have rear 02's or not in my truck. I looked in my stock file to see if I can turn them off but I do not see any option for rear 02's. If i do I would like to turn these off and plumb my wideband in, instead of welding a bung in. And yes this will be full speed density eventually.
