Results 1 to 10 of 10
Thread: LC-1 Installed
    Feb 2006
    Default LC-1 Installed
    I installed my LC-1 today following the tutorial and everything worked perfect!
    WB 02 is located on the downpipe of bank 2. I have read some posts re: ground problems so I solder spliced my analog grounds for LC-1 analog out 1 & 2, display ground and Flashscan analog ground to black w/white at pin 4 of OBD II connector (PCM ground). I placed my LC-1 heater ground and calibration switch/LED ground together on a common ground. I used a Innovate analog cable #3730 with the 2.5 connector removed for the cable to connect to my Flashscan AD1 input. Programming my LC-1 went as describe in tutorial. My display reads from 14.6 to 14.9 at idle and my first log matches AFR on display.
    Attached images of install and my first log just showing commanded and actual AFR
    I upgraded to Comercial license today and will be switching to Custom OS and 2 bar as soon as time allows.
Name:	WB sensor.JPG
ID:	521   Click image for larger version.
Name:	LC! Controller.JPG
ID:	522   Click image for larger version.
Name:	LC! leads.JPG
ID:	523   Click image for larger version.
Name:	AFR Gauge.JPG
ID:	525   Click image for larger version.
Name:	WB first test.JPG
    Michael
    2003 Silverado SS, Radix, 2.75" pulley, 160 stat, Magnaflow cat back
    Member ace68's Avatar
    Jun 2004
    Very nice, did you weld in the bung with the 02 in place? kida looks a little blue near the base of the o2 sensor.
    Feb 2006
    Quote Originally Posted by ace68
    Thanks! No, I actually had the bung welded in and plug installed for about a week before I did the LC-1 install. I am not sure what that is about, camera flash???? or ????
    Michael
    Senior Member mtnman's Avatar
    Sep 2005
    Quote Originally Posted by mcwarren
    You are my hero. My freakin LC-1 has lost proper calibration for the second time since I bought it last september. All connections are good and I havent recalibrated, but guess I'll have to unless I sell it or get a replacement. Glad its working for somebody.
    2003 2500HD,E-Fans, LT headers, Corsa catback, Outlaw intake.
    Oct 2005
    The LC-1 docs say to recal frequently. You can recal when its installed if you wait 8+hrs. I do mine every week or two.
    2014 VF SV LS3 Maloo.
    Sep 2005
    Hmm,
    I've heard from others that it shouldnt have to be re-calibrated that much. Only like twice a year.
    But yes, the manual does say "free air calibration should be executed frequently". But define frequently. Once a month? 6 times a year? Guess I'll ask the the guys at innovate about it.
    Aug 2005
    Where did you get the small lcd display in the picture ???
    Feb 2006
    Quote Originally Posted by stevieturbo
    I purchased my display at: http://www.dynotunenitrous.com/store...?idproduct=171
    Michael
    Oct 2005
    Hmm I suspect twice a year isnt frequently. But maybe once a week is too much. Let us know what innovate says.
    I remember seeing on the Innovate forum that they suggested recalibrating every 3 months.
  1. Can't get v2 installed on vista 64 bit
    By ThunderDan74 in forum FlashScan V2
    Last Post: February 26th, 2011, 04:42 PM
  2. LC-1's Installed
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: August 30th, 2007, 10:05 PM
  3. Need Help just installed my WB02
    By Spdfrk1990 in forum Gen III V8 Specific
    Last Post: June 16th, 2007, 01:00 PM
  4. OS3 installed
    By oztracktuning in forum Custom Operating Systems
    Last Post: January 22nd, 2006, 04:37 PM
