Originally Posted by
beav
Correct, I am not worried about the tuning part as I know EFILive will do that. I had to buy a different actuator motor for the turbo that came with the engine and if it is not installed while meshing the gear teeth in the correct position, then you run the risk of overtravelling to a hard spot and burning up the actuator motor.
Therefore, you are correct ATP, for starters I need to find the "home" positions of both the arm on the turbo cartridge and gear of the motor (when powered) and then mount it. But, does EFILive allow me to "home" the actuator motor?
Otherwise, is it possible to buy/rent starscan or something that will do it?
Anyone in the KY area that can do it for me?
Thanks!
