Results 11 to 20 of 29
Thread: Updating V2 firmware/bootblock
  1. #11
    Jul 2008
    boot block version OK, firmware update froze in the middle with $0101 error (no data received). now can only connect in dead poll mode. firmware update always freezes 1/5 of the way through if i try to update in dead poll mode. screenshoot attached. what do i do fix this? windows 7 x64.
  2. #12
    Can you try a different USB port on your PC...
    I notified Tech Support.
  3. #13
    Jul 2008
    i tried, no avail. thanks.
  4. #14
    Quote Originally Posted by vectorbundle View Post
    After it freezes, unplug the V2 - does the software unfreeze? If so, save a trace file (on the [F8: Trace] tab page) and send it to me at paul@efilive.com
  5. #15
    Jul 2008
    yeah, the update doesn't freeze per se, progress bar just stops and $0101 error window pops up. then i have to dead poll start the box to get it recognized. rinse, repeat, same thing. i will try to install the software and update firmware tomorrow on another machine (that one is dual boot W7/XP so i can try both OSs). if that fails i will email a trace. thank you.
  6. #16
    Jul 2008
    firmware update succeeded on the other system (laptop). i wonder why it failed on my PC, it's a new machine and same W7 x64 operating system.
  7. #17
    Dec 2007
    I am having similar issues with my V2. I just updated to the Nov. 7th V8 and V7 release and tried to update firmware and boot block on V2. Now the blue light stays lit and screen reads EfiLive flashscan V2. It will not update
    boot block and does not recognize current firmware or boot block. What am I missing? Current Firmware version 2.05.21 Sept. 25 2008 and boot block version 2.05.04 Oct. 16 2007 on V2.
    When I unplug usb cable and plug it back in it says Boot block has been upgraded license will be upgraded now, click ok an It then says Upgrade completed successfully.
  8. #18
    Did you read thru the pdf in post #1 here: Upgrading-from-older-boottblock-firmware
    What firmware/bootblock versions did you have prior to updating...?
    What did you do...?
    What does V2 do now...?
  9. #19
    Dec 2007
    What did you do...?
    Firmware/bootblock hasn't changed despite saying it was updated.
    I downloaded latest release V8 and V7 onto laptop, then attempted to update bootblock. Now v2 is basically unrecognized.
  10. #20
    Dec 2007
    The firmware/boot block never changed despite saying it was updated. Firmware 2.05.21 and boot block 2.05.04.
    I downloaded the latest release of the V8 and V7 software, then attempted to update the boot block. V2 is basically unrecognized now.
  1. Trying to update firmware and bootblock
    By nonnieselman in forum Black Box Logging
    Last Post: March 15th, 2014, 03:02 PM
  2. Where can I download Bootblock and Firmware files?
    By Code3Response in forum FlashScan V2
    Last Post: May 30th, 2012, 03:54 PM
  3. Old Bootblock and Firmware
    By JoshH in forum FlashScan V2
    Last Post: October 4th, 2011, 08:38 AM
  4. How do I update firmware and bootblock?
    By Sparky8370 in forum FlashScan V2
    Last Post: November 8th, 2009, 08:37 PM
  5. Latest Firmware and BootBlock?
    By Highlander in forum FlashScan V2 BB Logging
    Last Post: July 3rd, 2008, 02:29 AM
