Results 1 to 2 of 2
Thread: ECM PNs vs OS PNs
    Nov 2012
    Default ECM PNs vs OS PNs
    I put this question on the "Scanning" section of this Forum; maybe it should be here instead:
    I'm new to this DIY ECM tuning world and I'm trying to understand how to identify OS PNs that are compatible with a particular physical ECM PN. Example: I have a PN 12617630 ECM supposedly (did not see the donor vehicle) from a 2008 5.3L Silverado 4WD w/the factory OS. I've seen online references to an E38 OS PN 12617631; would that likely be the factory OS that's in this ECM? Is there any known standard PN relationship between the ECM PN and the factory OS PN it uses? I'd like to understand how to determine ECM vs OS compatibilty
    Unfortunately probably GM is the one people that would have a comprehensive parts listing like you are after.
  1. ECM PNs vs OS PNs
    By rkmason in forum General
    Last Post: November 7th, 2012, 03:46 AM
  2. New ECM ? Have question bout vin license an efi live to new ECM
    By Collins in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2012, 10:19 AM
  3. Need LBZ ecm, willing to give immacculate LMM ecm as exchange
    By badassmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 9th, 2011, 04:20 AM
  4. 02 OS into a 01 ECM
    By horsehaulin in forum Duramax LB7
    Last Post: September 28th, 2008, 03:57 PM
  5. 98 TA LS1 ECM or 01 WS6 ECM?
    By rat_rod_russell in forum General (Petrol, Gas, Ethanol)
    Last Post: July 21st, 2007, 02:39 PM
