Results 1 to 2 of 2
Thread: AutoVE setup question for serial instead of analog
    Member rumblebox's Avatar
    Nov 2010
    Default AutoVE setup question for serial instead of analog
    i set up the scan tool exactly like the AutoVE tutorial says, except instead of using "base efficiency numerator", i use "external wideband"?
    | 2000 firebird | LQ4 | LS3 top end | 226/231 .600 .602 114 | TCI 3500 | 3" x-pipe under-axle | BMR everything |
    Use the pid CALC.WO2BEN
    it is defined in the calc_pids.txt file located in post #1 of this thread: A-New-Twist-on-CALC-VE-Table-Computing-the-Entire-VE-Table
    Also, do not set your B3618 PE table to stoich (EQR 1.00).
  1. Serial wideband setup
    By articSS in forum General
    Last Post: November 30th, 2011, 03:42 PM
  2. Lost all wideband analog and serial pids
    By Wichita Dyno in forum General
    Last Post: August 23rd, 2010, 04:24 AM
  3. BEN is only for analog, right? How do I log BEN with serial logging?
    By Supercharged111 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 12th, 2009, 06:08 PM
  4. serial wideband autove questions
    By Slowrc in forum General
    Last Post: February 23rd, 2009, 04:01 AM
