Results 1 to 2 of 2
Thread: E38 ECM 12V Power Consumption on the Bench
    Nov 2012
    Default E38 ECM 12V Power Consumption on the Bench
    In case anybody can use the info, I just powered up an E38 ECM standalone on the bench (nothing attached) and measured the 12VDC input current. The 12V B+ input (J1 pin 20) pulls about 140ma and the switched 12V inputs (J1 pins 19 and 47) together pull another 10ma. I'm using a 12VDC 1.25A plug-in power supply and it seems to be able to power this ECM standalone no problem.
    Thanks for the info
  1. How much power needed for bench top programing?
    By kbracing96 in forum Tutorials
    Last Post: August 28th, 2010, 08:59 AM
  2. Bench tuning power source
    By killerbee in forum General (Petrol, Gas, Ethanol)
    Last Post: April 10th, 2009, 12:33 PM
  3. bench harness for ls2 and e38
    Last Post: March 29th, 2007, 12:39 PM
  4. E38 (06 Ls2) Bench Harness Diagram-help?!
    By Chuck CoW in forum General (Petrol, Gas, Ethanol)
    Last Post: June 15th, 2006, 10:19 AM
