Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: have not updated my controller in a long time. whats needed?
    May 2007
    Default have not updated my controller in a long time. whats needed?
    I am still running on v7.5.5 (build 88)
    Is there anything special i need to do to update my box? I tried to data log my car yesterday and all my pids were gone from my v2. I would have to scan through it on lap top , just want to get back in to doing some tuning, took a long break from cars. Thanks in advance. Chad
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
    May 2007
    So I tried to do the updates and now when I try to open efi live tune, I get error
    Cannot open file "c:\documents and settings\localservice\my documents\EfiLive\V7.5\user
    Configuration\calc_pids.txt" the system cannot find file specified
    It will not open, help!
    2000 NBM trans am.
    May 2007
    Quote Originally Posted by Aint Skeered View Post
    Also after following all those tutorials except one about changong .tun to .ctz I still get the same error code in above
    2000 NBM trans am.
    Do these steps in order:
    - save your calc_pids.txt someplace,
    - manually download and install V7 build 211 and V8 build 203 from the downloads page at www.efilive.com,
    - very carefully this thread before proceeding: Upgrading-from-older-bootblock-firmware
    - when you understand that pdf then proceed with your V2 upgrade,
    - after doing all of the above, see this thread: Setting-up-a-FSV2-from-scratch
    May 2007
    Joe I did not wait, I should have known better but like always I got impatient.
    I upgraded boot block and firmware already. My tune or scan icon won't open.
    2000 NBM trans am.
    What Windows OS are you using on your PC/laptop...?
    What does your V2 do when connected to your PC/laptop...?
    May 2007
    Windows xp on my acer laptop
    When I plug in my v2 it just lights up and shows the options but when I click on scan tool (f1) it brings me to the next screen and when I select pids (f1) it says options.txt not found.
    It says that on all options
    I have to leave for a while but will check back in a few hours. Thanks already joe
    2000 NBM trans am.
    Ok, you have to do this:
    May 2007
    I went to that page and did all of section 1.
    I don't understand the section 2, where do I go to save .ctz from .tun?
    2000 NBM trans am.
    Do you have any .tun files from your PCM...? Which folder are they located...?
  1. First time user, help needed flashing COS
    By jhinchy in forum Custom Operating Systems
    Last Post: December 10th, 2010, 11:47 AM
  2. whats this o.s.?
    By shane in forum Gen III V8 Specific
    Last Post: September 30th, 2009, 12:04 PM
  3. Whats going on here..help with PE
    By FFP in forum Gen III V8 Specific
    Last Post: October 23rd, 2007, 03:11 PM
  4. Whats going on here?
    Last Post: September 12th, 2007, 09:50 AM
  5. Whats this mean
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 8th, 2007, 10:52 AM
