2000 NBM trans am.
427 Dart ship block,Lme ported Ls7 heads 12.5 compression
246/262 .730/.712 112+4 low lash solid roller
Rmvb 4l80 with transbrake, 8" FTI converter
12 bolt Moser rear end with 4.10 gears
It is now wanting me to reregister my v2.
Where do I find my registration key and it has the issue date set as 01-jan-2000.
That is not right , I did find serial number just need reg key.
2000 NBM trans am.
youre reg key would have been in the box when you bought efi live on blue sheet of paper
stock sucks
If you can't find the blue card, then see this: Lost Registration Details
I notice in my scan tool, a lot of pids are not supported. I try to validate them and there is no explanation of why its not supported.
I would take a screen shot but dont remember how. any ideas?
2000 NBM trans am.
never mind, just connected to my vehicle and it validated on its own. Im a rookie again with this.
2000 NBM trans am.
well it was working, went to do a data log and the pids are back with red x's in them . What makes this change like that?
2000 NBM trans am.
I had to log through v2 only. Bbl
There was still several unsupported and could not see all that I needed in spark. I was trying to see the gr/cyl /sec and figure out where to pull timing for when I decided to add nitrous. This was unsupported .
2000 NBM trans am.
Post a screenshot of the PIDs tab showing the red X's.
Also, on each pid with a red X, do rightclick->More Info and see what reason it gives for the red X.
