Will wrong injectors data cause false Duty cycle readings ?
EFILive Tuner
Yes, but also your whole fueling will be skewed and the vehicle will have to be tweaked to get Fuel trims and WOT fueling corrected to whatever injector data is used.
LQ4, Pro-Flo, heads, Stock48 cam'd, twin TO4E 2001 C5 830rwhp/905rwtq
2001 GMC RCSB pt88/5.3/4l80e/14 bolt 11.34@123.2 best pass so far with a 1,82 60' @ 13lbs boost
