Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 54
Thread: 2011 gmc 2500 hd bootloader rejected ?
  1. #21
    Member JST's Avatar
    Jul 2007
    Works good with 7.5 ?
    2002 GMC 2500HD 4x4 SCLB STOCK MOTOR WITH TOMAN TUNING,FASS 150, M/A TRANS,11.90 ON A GOOD DAY IT'S MY WORK TRUCK,19 TO 21 MPG WITH ME DRIVING,THE TRUCK (OLD RED )HAS 909,000 MILE AND LOVING IT,285/75/16
  2. #22
    The V7 and V8 software cannot share a connection to the FlashScan device. If the V7 Scan or V7 Tune software is connected to the FlashScan device then V8 will not be able to connect to the FlashScan device.
    Make sure V7 is not running* when you try and connect using the V8 software.
    * Or at least that the V7 Scan Tool is disconnected and the V7 Tune Tool is not displaying any Read/Flash/Lock/PCM Info window.
  3. #23
    Member JST's Avatar
    Jul 2007
    Still not working,wow 2 day to try to get it going,do I need to uninstall 7,what the hell
  4. #24
    Ok, let's go step-by-step...
    what firmware version is in your V2...?
  5. #25
    Member JST's Avatar
    Jul 2007
    How do I find it ?
  6. #26
    Member JST's Avatar
    Jul 2007
  7. #27
    Quote Originally Posted by JST View Post
    How do I find it ?
    Connect up to the V7 software and select Help->FlashScan V2 / AutoCal V2 Licensing.
    Read the version number as circled in the image below.
  8. #28
    2.4.70
    Sorry, I didn't see that reply. EFILive V8 will not work with a device with firmware that old.
    You'll need to upgrade your firmware to V2.07.35. To do that, please read the document that can be found at:
    Start->All Programs EFILive->V8->Documents->Upgrading FlashScan.
    The most important thing to get right during the upgrade process is to make sure you get the firmware to exactly V2.04.72 before attempting to upgrade the boot block.
    If you attempt a boot block upgrade when the firmware is V2.04.70 (like yours is now) or V2.04.71 then chances are the V2 will become unresponsive and you'll need to return it to EFILive to be reset.
    The document explains the steps you need to take in more detail, please follow it carefully.
  9. #29
    Member JST's Avatar
    Jul 2007
    OK but this is killing me,I have so much in my V2 that I do not want to try this,in this area I have had to set up at lest 10 computers with EFI,it is at time so hard to work with EFI for others and now me ? ,I like EFI a lot WOW
  10. #30
    Unless you upgrade your FlashScan firmware you will not be able to use EFILive V8. Its not a difficult process to upgrade. But there are a couple of traps that can cause a problem.
    If you don't follow the instructions exactly, the worst case scenario means sending your device back to EFILive. You won't lose anything from your V2, we just have to reset the firmware here.
  1. Bootloader Rejected Need HELP Please
    By EVI in forum E37, E38 & E67 PFI ECM's
    Last Post: November 16th, 2012, 06:55 AM
  2. bootloader rejected
    By relentless addiction in forum Duramax LLY
    Last Post: May 25th, 2010, 07:26 PM
  3. Bootloader rejected
    By lilly in forum Duramax LLY
    Last Post: June 28th, 2009, 02:48 AM
  4. bootloader rejected
    By dmax687 in forum Duramax LLY
    Last Post: November 8th, 2008, 12:43 AM
  5. Bootloader Rejected
    By KWSUNDELL in forum Duramax LLY
    Last Post: October 21st, 2007, 08:32 PM
