Results 1 to 9 of 9
Thread: Sound?
    Member ace68's Avatar
    Jun 2004
    Default Sound?
    any way to record sound while scaning?
    Jan 2005
    what do you mean?
    I imagine you could use a microphone on your laptop and use an audio record device.
    Jun 2004
    I mean having sound from the run at the track recoded and spliced into the scantool like the wb and temp sensor.
    I don't know if it could be done but it would be nice to have some sound when reviewing the log.
    Jan 2005
    hm... video tape your laptop while scanning the pass
    Jun 2004
    I could do that this year I bought a cam but now that we are getting the new flashscan I don't think I'll bring the laptop with me to the track anymore.
    Sample rate would be too slow.
    Jun 2004
    awww shucks
    May 2019
    I may have part of a viable process for logging sound? Can someone help with #5?
    1. Setup to log whatever data you want using EFI Live.
    2. Setup to log sound with a separate device such as an Android device, iPhone or laptop
    3. Export the EFI live results to ASCII text format (decibels and time)
    4. Export the sound log to ASCII text format (various parameters and time)
    5. The key part I am missing - how can we align time between the two ASCII text exports?
    6. Graph the EFI live ASCII text export and overlay the sound ASCII text export.
    Thank you for any help.
    You should be able to... capture an EFILive log and look at the timestamp to see if it agrees with your watch/clock.
  1. bad sound
    By justin123 in forum Duramax LB7
    Last Post: September 14th, 2009, 11:02 PM
  2. Sound like a bad WB02. Driving me crazy
    Last Post: September 20th, 2007, 01:40 AM
  3. No update sound on RTACS
    By VT LS1 NZ in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2007, 10:10 AM
