Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: VE table calculation for 60#
    Senior Member Behold's Avatar
    Apr 2010
    Default VE table calculation for 60#
    I have on order my Siemens 60# injectors. There going in to my Holden VT LS1 with LS1B controller. I'm running a COS5 OS and its tuned for 42# at the moment but I'm doubting the VE Table is that great as the injectors are a bit of guessed data.
    Am i right i need to scale my VE What do I need to do? do I take a standard table scale it and add 5% and scale up my BOOST table to match and go for an AUTO VE tune and see what it shows? Is there any other areas that need changing to suit the 60#s????
    Oh to add. Reason I have moved to the 60s is I hear there good. There is usable injector data and although running 5psi that's likely to be upped to 8-9 psi once intercooled and my 12rib pulleys are all set up.
    Thanks Antony
    Holden Commodore GTS - LS1 5.7
    12 rib Crank Driven Vortech V2 Centri Charger (Intercooled) 9 PSI.
    LS6 Intake
    LS6 Heads
    YT 1.7 Roller Rockers
    BTR Dual Spring with Ti retainers
    BTR Hardend 7.400 Push rods
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    PCM LS1B with 512KB Running COS5 v01290005
    May 2008
    Hi, depending on which 60LB injectors you have, the best bet would be to find an existing tune with the injector parameters for the ones you have. Those values need to be fixed before you change the VE table. There are values for injector flow rate, small pulse, and voltage, and timing.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    Apr 2010
    That's a given. I have some data from a couple of tunes I grabbed a while ago. Not sure how accurate it is. There Siemens and are the same as I believe is on the Greg banish DVD/data. So many here will have some knowledge and on a few other sites and worst case I can buy the DVD.
    Once the IFR, All the different Offsets/PW Are in. There is some scaling needed. Just what I heard. This is because of a limitation on the OS? I think some of the injector data also needs scaling.
    I might be wrong. Hence checking.
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    No... when you insert the injector values/tables for the new injectors the VE table should be left alone
    ( of course, if the VE table was not corrected originally, then it will still be in the same uncorrected state )
    you would have to scale the IFR/VE under the following circumstances:
    - exceeding the MAF limit;
    - exceeding the IFR max limit (60 lb/hr injectors do not exceed).
    The LS1 PCM sets a limitation on the MAF at 512 g/s... so you might be running into this, so you will need to scale MAF, VE, IFR.
    [ i.e. you're running into the MAF limitation not the IFR limitation ]
    May 2008
    I'll take a look when I get home. Are they the skinny Simmons injectors? I think I have a tune for the Bosch 60LB injectors.
    48 LB injectors
    T70 turbo.
    Apr 2010
    Perfect Joe. I'm not running a MAF (got rid of that slow responding, bottleneck causer!!) I was told the 60s were over the limit. I'm assuming this is where they meant. So easy job. Put the Injector info in and then re auto VE to remove the problems caused by my 42s.
    Nevin, there Siemens Deka units. FI114961 (EV1 compatible) the same as the P/N m-9593-lu60 for the ford racing.
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    Apr 2010
    Quote Originally Posted by foakley View Post
    Hi mate,
    Here's my ls1b cos5 tune with 60lb siemens injectors.
    Hope it helps.
    Cheers.
    Thanks for that. Ill take a look and compare with some of my others.
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
    Apr 2009
    Quote Originally Posted by Behold View Post
    These will require scaling to work correctly in the older ECMs. They flow ~60#/hr at 3bar, and closer to ~73#/hr at GM's 4bar nominal pressure, which is beyond the ECM limit. Plan on about 24% reduction to stay within the ECM's capability while still retaining the most resolution possible. I did this exact scaling example in the second DVD when I was calibrating a supercharged Z06.
    Remember that any injector errors will likely lead to a mirror-image error in the airflow model (whether it's MAF or SD) that can eventually give you weird driveability quirks. If your previous 42# data was off a bit, you may find yourself "fixing" areas of the VE model now that you have new injectors with new data.
    ~Greg
    Calibrated Success - EFI Training and Tuning Done Right
    GM Beginner's Guide DVD available now through Summit!
    Engine Management: Advanced Tuning - Amazon's best deal for the EFI crowd.
    Ah, I was in a hurry and I forgot about 3-bar -> 4-bar scaling (4-bar flowrate exceeds range), thanks Greg.
    Apr 2010
    So is it just the Flow you scale? or do all the PW and Adders need scalling too? then drop the VE by the same percentage.
    As to the current VE Im thinking its going to be a mess that need almost a complete redo. Nothing a VE Tune will not clear
    Thanks Antony
    LS6 Intake
    LS6 Heads
    Comp Cam JAMCAM
    2 Bar Map
    Mafless
    LS2 Coils
  1. VSS Calculation
    By FUBAR in forum Cummins 5.9L
    Last Post: July 7th, 2012, 04:30 AM
  2. {B8001} Normal VE Calculation
    By limited cv8r in forum E37, E38 & E67 PFI ECM's
    Last Post: July 24th, 2007, 08:45 PM
  3. Need help with WB calculation.
    By Redline Motorsports in forum General
    Last Post: December 13th, 2006, 11:50 AM
  4. VE calculation and tuning
    By 01blkss in forum General (Petrol, Gas, Ethanol)
    Last Post: March 6th, 2006, 10:25 PM
  5. LC1 CALCULATION
    By TAQuickness in forum General (Petrol, Gas, Ethanol)
    Last Post: July 26th, 2005, 06:23 AM
