I have on order my Siemens 60# injectors. There going in to my Holden VT LS1 with LS1B controller. I'm running a COS5 OS and its tuned for 42# at the moment but I'm doubting the VE Table is that great as the injectors are a bit of guessed data.
Am i right i need to scale my VE What do I need to do? do I take a standard table scale it and add 5% and scale up my BOOST table to match and go for an AUTO VE tune and see what it shows? Is there any other areas that need changing to suit the 60#s????
Oh to add. Reason I have moved to the 60s is I hear there good. There is usable injector data and although running 5psi that's likely to be upped to 8-9 psi once intercooled and my 12rib pulleys are all set up.
