Thread: Generic ECM / TCM Conections
    Jul 2007
    Default Generic ECM / TCM Conections
    Hi All,
    Has any one used scan tool to connect to a "Generic" controller? I see that there is an option to connect to VPW / CAN bus controllers, both ECM and TCM, but was wondering what can be done with this option.
    I'm hoping there is a way to log non GM controllers, maybe if they use STD. SAE PID's or even possibly a configuration for custom PIDs. The V2 is a powerful device and having the ability to log other controllers, even without the corresponding tuning calibrations, would be very good.
    Simon.
    Jul 2007
    Bump.....
    I know things have been a bit busy
    Hi Simon, where do you see this...?
    Nov 2007
    I havent tried the "Generic" controllers but if you want to scan a CAN ecm then just select any CAN ecm e.g. E38 and add in the SAE PIDs. It usually a pretty slow data rate though if you add too many.
    Jul 2007
    Ahh, OK, so maybe just any CAN controller will work for me.
    Joe, this is in V7 Scan tool.
    Click the "green" button to connect to a controller.
    In the "Select Controller" drop down box, go all the way to the bottom and there are 5 "generic" listings. ( 3xVPW and 2xCAN )
    To add some info for others, I've been playing with a Triumph motor bike using a free tuning tool. the software works OK for modifying the basics, but has limited (almost nothing ) logging capability and requires the laptop to be connected. It's a little harder to log real street conditions while trying to hold a laptop, so using BBL and the V2 would be perfect.
    I'll have to try the tips above and see if I can get any data from it. RPM, TPS and MAP would be about what I want.
    Simon
    Ah... I hadn't noticed that... I'll try it out.
  1. Will not connect pcm/ecm/tcm
    By Sleeping in forum General (Petrol, Gas, Ethanol)
    Last Post: April 24th, 2011, 08:01 AM
  2. Do I need a new ECM and TCM?
    By smitty91 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 22nd, 2010, 10:40 PM
  3. ECM AND TCM BCCs
    By RetroAus in forum Gen IV V8 Specific
    Last Post: November 13th, 2007, 12:00 AM
  4. Tuning my TCM along with my ECM??
    By Wasted Income in forum FlashScan V2
    Last Post: August 20th, 2007, 11:58 PM
  5. Flash scan cable scanning generic OBDII
    By Dark Angel in forum General
    Last Post: February 25th, 2006, 10:27 AM
