Page 7 of 7 FirstFirst ... 567
Results 61 to 66 of 66
Thread: TBSS 4L60e to 4L80e T42 Swap
  1. #61
    Jun 2007
    So to clarify, without the blower hooked up, from a STOP it runs just fine? As in no dropping the Bank 1/2 fueling?
    Sounds like if this is the case, you simply arent getting enough fuel to the engine. What size are your feed lines TO the fuel rails?
    Thats what we figured but the Fuel Pressure never drops???
    Can I lose fuel in the rail you think and keep fuel Pressure?
  2. #62
    Jun 2007
    Swap the injectors left/right across banks.
    I try that.
    Goona run some more NA test before I put the belt back on.
  3. #63
    Quote Originally Posted by Evilz28nos View Post
    Honestly at this point it sounds like you've done all of the normal diagnostics and then some, IDK what else to say.
  4. #64
    Jun 2007
    Pulling the tank and I'm going to flow each pump individually and together on a bench.
    Then I am going to run the same test in the car at the rails.
    I'll let you guys no.
  5. #65
    Jun 2007
    Forgot to mention I pull the Boost Regulator vac hose and it will spin all 4 tires now before running out of fuel from the HIT.
    Regaurdless of what the gauge says at the rail I am out of fuel.
  6. #66
    Ah so you are losing fuel in boost...interesting.
  1. t42 4l80e tune
    By eacostad in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 10th, 2013, 01:06 PM
  2. 4L80E swap into 2006 6.0L truck with 4L60E
    By powermonger in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 19th, 2010, 03:59 AM
  3. 2000 4L80E with T42?
    By v8vegaman in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 21st, 2009, 03:27 AM
  4. 4L80E into TBSS
    By 64camino in forum E37, E38 & E67 PFI ECM's
    Last Post: December 19th, 2009, 05:38 PM
  5. 4L60E to 4L80E swap
    By hquick in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 22nd, 2007, 08:48 PM
