Thread: Roadrunner not updating
    Nov 2012
    Default Roadrunner not updating
    Hi, I'm new to efi live and roadrunner. I have everything commincating and scanning but when i make a change to the cell that is being used in doesn't change. i'm playing with timing table. i can take the 28* cell and change it to 14*. no change. still shows 28 on scanner. I'm just at idle in a stable condition. I have rtacs activated. thanks.
    Dec 2005
    Are you in emulation mode and is it enabled for real time or is it just connected and not in real time mode ??
    www.mscservices.net
    Nov 2012
    Yes I'm in emulation mode. The curser is floating live on both the scanner table and tuner table. Just won't take the chang I type in. The number will change in the cell. It's like it's not updating the roadrunner automatically.
    Nov 2006
    Did you press enter?
    Is Adaptive Spark enabled?
    LC-1 WBO2
    Dec 2005
    did you set up the RTACS parameters
    www.mscservices.net
    Nov 2012
    Thanks for all the suggestions guys. Everything was working properly I was in the wrong timing table!
  1. need help updating V2 please....
    By oregonfireman in forum FlashScan V2
    Last Post: August 15th, 2012, 06:02 AM
  2. RR not updating.
    By John02SS in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 28th, 2008, 12:47 PM
  3. Updating
    By Eddysel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 26th, 2008, 11:53 AM
  4. Help with updating os
    By cmitchell17 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 14th, 2007, 10:57 AM
