I did uncheck the use high speed box. After that is when it comes up not lisc to my controller
So you previously licensed this ECM...? And now V8 does not recognize it...?
Please send the following files:
The V8 trace files (*.htx) from the folder: \My Documents\EFILive\V8\Trace
The V7 trace files (*.blx) from the folder: \My Documents\EFILive\7.5\Bug Reports
Your V2 license backup file (*.lbu). Generate a backup file using the V7 Tuning Tool menu option: Help->FlashScan V2/AutoCal V2 VIN Licensing..., then click on the [Backup] button.
Send all the files to me at paul@efilive.com
The V7 software is getting confused by the PCM sending back a corrupt serial number.
Its a known issue with LB7, LLY and P10 controllers.
Try using the V8 software to verify that your truck's PCM is licensed.
i.e. click the [Check License] button on the cal-flash page:
If the license checks out ok, then you can use V8 to flash your truck.
Let me know if V8 is not able to flash your controller, then I'll send you a link to download the latest beta software that may resolve the issue.
Thanks. I'll see if he will drop it off tomorrow!
After I checked the lisc in the v8 it said Security Access Denied($33)
Are you logged in with admin privileges...?
Are you logged in as the same use who installed EFILive (and that user had to have admin privileges)...?
