Results 11 to 20 of 28
Thread: Trouble loading Files
  1. #11
    Nov 2012
    I did uncheck the use high speed box. After that is when it comes up not lisc to my controller
  2. #12
    So you previously licensed this ECM...? And now V8 does not recognize it...?
  3. #13
    Please send the following files:
    The V8 trace files (*.htx) from the folder: \My Documents\EFILive\V8\Trace
    The V7 trace files (*.blx) from the folder: \My Documents\EFILive\7.5\Bug Reports
    Your V2 license backup file (*.lbu). Generate a backup file using the V7 Tuning Tool menu option: Help->FlashScan V2/AutoCal V2 VIN Licensing..., then click on the [Backup] button.
    Send all the files to me at paul@efilive.com
  4. #14
    Nov 2012
    I sent you a email!
    Nov 2012
    I think I didnt try flashing it in V8 since it was showing the error message. But yes I previously lisc the ecm!
  6. #16
    The V7 software is getting confused by the PCM sending back a corrupt serial number.
    Its a known issue with LB7, LLY and P10 controllers.
    Try using the V8 software to verify that your truck's PCM is licensed.
    i.e. click the [Check License] button on the cal-flash page:
    If the license checks out ok, then you can use V8 to flash your truck.
    Let me know if V8 is not able to flash your controller, then I'll send you a link to download the latest beta software that may resolve the issue.
  7. #17
    Nov 2012
    Thanks. I'll see if he will drop it off tomorrow!
  8. #18
    Nov 2012
    After I checked the lisc in the v8 it said Security Access Denied($33)
  9. #19
    Are you logged in with admin privileges...?
    Are you logged in as the same use who installed EFILive (and that user had to have admin privileges)...?
  10. #20
    Nov 2012
    yes I am! It has worked fine on every other truck but this one. I tuned another truck Sat with it no problem!
  1. Loading Original Files
    By Dik in forum AutoCal
    Last Post: August 7th, 2012, 11:24 AM
  2. Trouble loading pid selection to BB
    By Picto in forum Black Box Logging
    Last Post: November 15th, 2010, 05:00 AM
  3. Trouble loading DSP5 Tune
    By Dmaxx 02 in forum Duramax LB7
    Last Post: September 14th, 2009, 07:12 PM
  4. Trouble loading 2002 OS in 1999 PCM
    By Beer99C5 in forum Custom Operating Systems
    Last Post: October 9th, 2007, 05:20 AM
  5. Trouble loading V7.31 after system reinstall.
    By johnv in forum General (Petrol, Gas, Ethanol)
    Last Post: March 5th, 2006, 08:40 AM
