Results 1 to 3 of 3
Thread: P0106 nightmare
    May 2012
    Default P0106 nightmare
    This truck is an 08, everything deleted, running an H&S Black Maxx, constantly throws a p0106 code and goes into reduced power mode. My plan was to use the H&S to return to stock, then full flash an early 07.5 calibration on to it and then build from that base. Thoughts?
    The p0106 is a map sensor code, maps been changed, tss, MAF, plugged / unplugged the EGR. Open to ideas...
    May 2009
    Might be ECM have u checked harness?
    Mar 2012
    ive seen this before when turbo actuator fails & pops fuse. check under hood fuses!!!
  1. AFR Nightmare
    By RevGTO in forum Gen III V8 Specific
    Last Post: November 18th, 2012, 07:21 PM
  2. P0106 map
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: January 25th, 2010, 05:01 PM
  3. Help P0106 & P0101
    By Moonder in forum General (Petrol, Gas, Ethanol)
    Last Post: December 22nd, 2009, 12:32 AM
  4. Upgrading Nightmare. =(
    By Stealth97 in forum FlashScan V2
    Last Post: March 3rd, 2009, 08:53 PM
  5. 7.5 Software update nightmare.
    By JOHNBOY in forum Tips and tricks
    Last Post: November 23rd, 2007, 10:42 AM
