Results 1 to 4 of 4
Thread: AFR at low rpm with large cam
    Nov 2009
    Default AFR at low rpm with large cam
    Most everything I read says that you are shooting for the stoich ratio when tuning but then I also read that at low rpm large cams tend to have unburnt gas so the afr reading appears to be lean when its not.
    When tuning is there a general guide as to what the AFR should be at low rpm. Also, what range of rpms and MAF hzs are effected.
    That is correct (unburnt fuel = unburnt oxygen = lean reading on wideband).
    Tune for the lowest MAP (i.e. the most vacuum).
    May 2010
    Like Like Like
    EFILive Tuner
    Nov 2009
    Thank you Joe!
  1. e38 large cam nightmare.
    By Mike@sic in forum E37, E38 & E67 PFI ECM's
    Last Post: November 7th, 2011, 01:55 PM
  2. Is 45* too high for low load low rpm cruising?
    By the Dragon in forum General
    Last Post: February 13th, 2011, 01:43 PM
  3. Large cam idle help
    By VHR in forum Gen III V8 Specific
    Last Post: December 6th, 2006, 03:26 PM
  4. looking for big help with tuning an extremely large cam in my ls1
    By 01blkss in forum General (Petrol, Gas, Ethanol)
    Last Post: August 21st, 2006, 08:52 AM
  5. looking for big help with tuning an extremely large cam in my ls1
    By 01blkss in forum Custom Operating Systems
    Last Post: May 11th, 2006, 07:07 AM
