Results 1 to 9 of 9
Thread: pulse width
    Nov 2012
    Default pulse width
    I came across a thread on another forum that got me to questioning myself on how I understood the pulse width tables actually functioned. Is the numbers in the table D0502 the actual time in microseconds that the ecm opens the injector for? That is how I've always understood it but this other thread led me to believe that these numbers were merely a reference point for some type of calculation the ecm does.
    Nov 2010
    Default pulse width
    Quote Originally Posted by Gwoody View Post
    It is a MAX pulse in each cell the ECM uses..it does not use each value as just that. You set a value in the cells to set a MAX pulse per cell pulse.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Nov 2012
    So, is the actual pulse width determined by some sort of calculation within the ecm and merely raising the MAX values in the table gives a higher MAX target?
    Feb 2007
    The ECM looks at the actual fuel rail pressure and the commanded fuel quantity. It then uses those values to look up the correct cell in the main injection pulse width table to determine the proper pulse width to fire the injector.
    Nov 2012
    So if the commanded fuel rate is 100 mm3 and the rail pressure is 11000 the ecm will see the coresponding cell in the pulse width table and uses this number for the amount of time the injector sprays? This is how I understood it to work but Les's post above states it a little differently.
    Nov 2010
    Default pulse width
    In a sense we are both correct..if you build a MAP in the logging sw, and run a log, the MAP will populate with values in the corresponding x/y axis BUT the values will be a variant of the commanded value. Table values are a MAX, not a absolute.
    Les Szmidt
    2007 5.9 Dodge Ram
    Nov 2012
    Is the reason they are a variant due to the fact the tables on the x/y axis have limited number of columns and rows so most of the time the actual readings are always somewhere in between these specific values and so the coresponding pulse width will also be that way?
    Nov 2010
    Default pulse width
    That is how I understand/approach it.
    Les Szmidt
    2007 5.9 Dodge Ram
    Nov 2012
    Thanks for helping a newbie trying to understand all this.
  1. MM3 or pulse width?
    By jlb350 in forum Cummins 5.9L
    Last Post: August 14th, 2012, 01:52 AM
  2. Pulse Width Calculations
    By robof16 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 1st, 2012, 02:31 AM
  3. Small Pulse Adjust/Low Pulse Width Injector Offset
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: September 4th, 2007, 09:05 AM
  4. Injector pulse width
    By Bruce Melton in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2006, 01:49 PM
  5. Pulse width Modulation???
    By vetteboy2k in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 25th, 2005, 01:41 PM
